Crysis 3
Publisher: EA
Mixing the open-world combat of Crysis with the more tightly scripted urban jungle of Crysis 2, Crysis 3 is a smorgasbord of visual effects and polygons galore. With DirectX 11 support, high resolution textures and incredibly detailed characters models, it's laid down the gauntlet for the next generation of consoles and games alike when it comes to gorgeous graphics
We test using the Very High detail preset and with Very High texture resolution. lens flare and motion blur are both enabled, although due to its heavy performance impact, anti-aliasing is disabled.
As explained earlier, we use a custom macro-driven 60 seconds play-through from the single player mission Red Star Rising. The 60 seconds of gameplay takes place in a large open environment heavy on water and particle effects. Each test is repeated three times, with the average result taken.
AMD Radeon R9 295X2 8GB
Nvidia GeForce GTX Titan Black 6GB
Nvidia GeForce GTX 780 Ti 3GB
AMD Radeon R9 290X 4GB
Nvidia GeForce GTX 780 3GB
AMD Radeon R9 290 4GB
Nvidia GeForce GTX 770 2GB
AMD Radeon R9 280X 3GB
Nvidia GeForce GTX 760 2GB
AMD Radeon R9 270X 2GB
Nvidia GeForce GTX 660 2GB
AMD Radeon R9 270 2GB
XFX Radeon R7 265 Core Edition 2GB
Nvidia GeForce GTX 750 Ti 2GB
AMD Radeon R7 260X 2GB
Frames Per Second
Nvidia GeForce GTX 480 1.5GB
Nvidia GeForce GTX 650 Ti 1GB
Nvidia GeForce GTX 550 Ti 1GB
Frames Per Second
20
30
40
50
60
70
80
Frames Per Second
